1 - 8 of 8 Posts
I'm in the throws of a ZD30 to TD42Ti conversion. The TD42Ti donor engine was alleged to be a one owner, 155 000km, tested and reported to be running like a dream. Conversion complete, first start and there's a knock in the bottom end?? What could go wrong during the conversion to cause this? Is there any way an engine could be bodgied up to run well during testing and crap itself shortly after? Or is someone telling porkies? Thanks for reading.
Rogue
nissan gu patrol
Just thinking outside the box a bit..
Are you using new engine mounts? Is the motor hitting on anything?
All new mounts, hoses, belts, intercooler, turbo, pump, injectors and a heap of other stuff. Conversion done by a shop that does them all the time.
united fuel injection
I would suggest the engine has been transported incorrectly and the sump has been pushed up and now the conrod is hitting it around number 2 cylinder .
Its very common as there isn't much clearance between them and the sump anyway .
Put youre hand on there when its running and you will feel it
Reactions: Strzelk
You were right TD. The sump was damaged in transit causing the knock. Sump straightened - hopefully all good. Cheers
1 - 8 of 8 Posts
