Well after last trip to wesburn my clutch started to slip a bit but now when I go to take of or change gear it feels like the diff is knocking or something with the tail shaft .. I'm no mechanic so I don't no exactly what's going on but when the clutch engages it jerks around a bit and it's pretty hard and a little noisy.. Any ideas or help?
what model, i have a gq that does the same thing, it got worse after i took the centre out (what a mission )to get it checked, pinion loose and he tweeked it a little. it feels like the arse end is going to fall out if you put it in nuetral stopping at lights. They said it could be in the lay shaft (supporting gears )worn???? guess i will drive it till it breaks then i will know
