Hey guys,
Just wondering if anyone can help me out, i have a 93 GQ that has a knocking noise coming from the front left when going around right hand corners or hard acceleration.
any ideas of what could be causing this would be fantastic.
cheers in advance
Matt
check your body mounts. if loose and tightening doesnt help, go to clark rubber or somewhere similar and get thick rubber.
remove bottom mounts cut rubber to size and refit rubber then bottom mount. Just acts like a spacer. but saves you lifting the body :D
if mounts are ok, check all suspenion bolts, brake caliper or anything loose under the bonnet.
Maybe this: I had broken steering limiter on the left side which caused the tie rod end body scrubbing against radius arm when turning left hard. Replaced the limiter.
