Started building october last year. Picked up a 88 tb 42 shorty with a fair modification list and decided i wanted a td42. Ended upbuyingt a fairly clean safari shell off family friends. Found a td42t safari with gt2871with billet wheel, auto with wholesale autos extreme valve body, external wastegate locked to 25 psi and 10mm pump camplated and boost compensated. Downside was the body was absolutely hammered.
The plan was too engine and wiring loom convert out of the rough bodied safari, get roadworthy with standard suspension and diffs, and then diff and suspension swap out of the 88 shorty. build took around 6 months, with work most weekends and some weekday afternoons.
Many issues have been encountered in the build, with my biggest mistake being not extensively labelling all parts of the loom. which led to a fair few electrical faults.
Buds long arms, crossmember and dropboxes, laminated gu diff, 3 inch flexi coils and 10 fox remote reservoir shocks. Ready to go from 88 shorty
24v td42 automatic wiring loom
forklifts are the best for pulling engines, although a leaking ram ended up smashing my windscreen
engine bolted in
bought this 18 inch dual bypass transmission cooler off ebay
engine bolted in
