1 - 3 of 3 Posts
Hi all, long time reader and never posted.
I'm wondering if anyone has done a cab swap on a Gu can chassis leaf spring and fitted a Gu wagon cab to the lead spring chassis. I will chopping the wagon to dual cab ute. I'm wondering if the cab mounts can be cut off and used on leaf spring chassis or could it be better to just take my engine and box and put it into a wagon roller? Any suggestions would be great. Thanks
nissangu
What would be the benefit of putting a wagon on a leafy chassis? A well setup coil spring will take plenty of weight?
just a good guy.
2009 gu ute
I would be putting your engine and gearbox in a wagon then you will have coils all around. is it 4.2 or a 3 ltr . also much less work changing over running gear compared to swapping bodies.
1 - 3 of 3 Posts
