Have 99 td42
Just swapped box and transfer and now have instant chassis lubrication anyone had a similar leak, im in the middle of woop woop and near Port augusta just topping up atm
There is a void between the g box and trans case,with a drain at the bottom.both g/box and trans case have a seal where shaft carries to trans case,just monitor both levels until you are in a position to remove trans case to access either/both seals,is it possible either are overfilled ?
Hmm yeah could be have been, checked both while level but still have this spraying from somewhere, been seriously frustrating
If the shifter boot is damaged,oil can be slung out and the draught under the vehicle will rust proof the chassis.The seal could have been damaged when the trans case was off/on,especially if it was fitted without using a trans jack,it's a weighty bugger 💪 to align and support.been there got the stubbie holder ;)
