1 - 3 of 3 Posts
Well, I’ve got a leaking fuel line that goes into the rail of my ZD30 Ute, it’s leaking out a bit, would the loss of pressure cause my car not to start or would it be something else broken?
In addition to the problem of fuel leaks, you also have a problem with a flammable substance under the car.
2. You will have a problem if the diesel engine draws air through that hole.
On my Patrol I replaced with cooper tubs.
1 - 3 of 3 Posts
