People, as per the title has anyone upgraded their interior lights to LED and if so was easy and did you get a better light as a result??
did the upgrade still work with the auto dimming etc??
squiz
I did the led on my previous car. I found however that these were hard to get good ones.
Did have nice ambience with the white light rather than yellow however.
Haven't bothered with the patrol.(as yet)
I tried the panel type LEDs mentioned above. There isn't much to stick them too in the roof light areas, and I found that after a while the LED panel/double sided tape separated from the fixture. My Patrol is a Y61 - may be different in the Y62.
I now have the ones with LEDs mounted directly on the festoon or globe replacement. Not as many LEDs as the first ones I had, so it is no where near as bright, but still OK.
2X White 31mm 1210 SMD 16 LED CAR Interior Festoon Dome Light Lamp Bulb DC 12V | eBay
