Hi everyone,
Firstly I've only just joined the forum but been a pretty in depth reader for quite some time and have solved many problems with the info posted here.
Anyway I have an issue and cant seem to find an answer anywhere.
As the title mentions I left my ignition on for probably 20-30mins while troubleshooting my spotlight install (found to be a faulty fuse). Had ignition on as the beeping was annoying me (I know I should've just shut the door but for some reason didn't do that).
That is all that happened, car ran fine since having the car (just over a year) and now it won't start. The engine cranks, but just wont kick over.
Ive tested the ECM relay behind the dash near the key barrel and seems to work fine.
Glow plug relay works, and have 12v going to the rail. Along with resistance on the glow plugs (to test they aren't broken) I haven't removed the glow plugs to have a look at them but feel they should be fine due to the timer.
I have cracked a couple injector fuel lines and nothing comes out after cranking a quite a few times.
Pulled codes 0403, 0703, 0707, 0905 and 1405
Ill say when I pulled the codes i had the turbo pressure sensor disconnected (0905) and after checking the next day I also had the plug disconnected going to the injector pump (cant believe it). And also the 1405 confuses me, the little flashing red light does turn off when the key is inserted.
So because i had the injector pump unplugged, I plugged everything back in and cleared the codes, tried cranking the car about 5-8 times (battery died again), checked for codes and got the 0505 (no errors).
One thing I do notice is the little pump thing above the fuel filter does become soft again after cranking or waiting about 20-30 seconds. Can't see fuel leaking anywhere so don't know where its going.
After reading through the Haynes book, I found it says not to leave ignition on foe excessive amounts of time without the engine running. But that's where it stops, I need to know why? What happens when or if you have done exactly that?
If it happens to be the injector pump then I gotta make sure 100% as that is a big and expensive job. I find it hard to believe that simply leaving the ignition on could cause any serious damage though.
Has anyone got an idea what happened?
