Hello, I'm having trouble with priming up a fuel filter after it has been changed. It's just not building pressure. I spent 3 hour yesterday pumping and trying a few things to get fuel in the filter. I ended up taking off the feed hose to the IP and sucking the fuel through with some clear 10mm hose but kept returning to the tank and I tested it for suction pressure when I took it off.
The Fuel isn't meant return after it has pasted the plunger? It should have a check valve to prevent that?
