1 - 8 of 8 Posts
nissan patrol gq
Hey guys, recently purchased a GQ patrol. I've noticed a number of times when on the freeway the clutch becomes a lot firmer. Wondering what's causing this? The clutch is incredibly light as it is.
I automatically assumed I had a leak in the master cylinder but I'm unsure as the clutch pops back out as normal and I'd assume if I had a leak the clutch wouldn't pop back out without some convincing.
Anyone got any seggestions of what I should check next?
naturally asthmatic
Vacuum leak or booster diaphragm or booster seal.
nissan patrol GQ ute
What he said, just fixed mine, it was a booster seal. $65. About 250 for a rebuild if its the diaphram.
Hey, welcome to the forum Will. Good to see you signed up here mate ;) Lots of good advice and trips to be had.
nissan patrol gq
ive just found my vacuum tester so ill test that tomorrow.
how easy is it to replace the booster seal? im unfirmilier with nissan set ups....
i split the little vac hose from the back of the alternator from memory and it made either the brake or the clutch like a rock to push.
1 - 8 of 8 Posts
