1 - 2 of 2 Posts
nissan patrol guIII
Just want some advice, 04 Guiii, oil catch can, egr blocked, hpd boost control, car goes into limp mode mainly once or twice in the morning then o.k, just had maf replaced but still have same issue, no fault codes are showing, this has been going on since boost control was installed so we put it back too factory, ie. no boost control, still did it, any ideas would be appreciated, cheers
Currently in PAD rehab
The blocked egr will be thd culprit. Ill bet it only does it first thing in the morning on a slight hill.
Options... put a needle valve in to slow down the spool up (hpd boost control doesnt do this), or install a jdvm as per the existing thread.
Even with all my mods i still get limp on cold mornings... something im working on.
Drop it back a gear or let it warm up a bit more till spring arrives :)
1 - 2 of 2 Posts
