I have another question: I go ski in every winter. The place where I stay the temperature can be around -9 to -15 degrees at the night, and also very cold in the early morning. I understand that the Lithium LifePo4 battery will not accept charges at these kind of cold temperature. But I assume I can still crank the engine? What happens after the car is running, the alternator is connected to the battery directly. I was told in case the BMS disconnect the battery from the alternator, then the alternator may get damaged, so will other car’s electronic devices (such as ECU, etc). How does the BMS manage to handle the system in such cold temperature?
