1 - 2 of 2 Posts
Hello
My td42 gearbox has started to jump out of third gear while under load eg (accelerating normal driving), hold it in with your hand drives fine, no more noisy than it has always been, only other sympton I have noticed in the last couple of months is started to leak a small amount of oil from between the gearbox and the transfer spacer
I have a replacment box here but really don't want to pull the box out if it's not needed
so am wondering if anyone on here might have some knowlage as what might be the cause of this problem, as I already said the box still seems fine other than the jumping out and 3rd is the only gear it does it in :/
BORDERTREK 4X4 & FABRICATION
Bearings, rings, and bushes are probably worn out on the mainshaft
1 - 2 of 2 Posts
