1 - 5 of 5 Posts
gday, fellas its probably been asked a million times;) will a 150 litre longrange main tank from a 95td42 gq (no body lift) fit up and bolt into my 2013 gu zd30crd (no body lift) and if it dosnt is there much involved to modify it to suit as im certain the rear ends are the same
cheers adrian:eek:
cheers adrian:eek:
yes it will.
Depending on brand of tank you may get a top control arm hit the tank on full articulation. There a number of outlets that sell a bent arm to deal with this.
Cheers,
nissan patrol gu4 wagon
He his talking about main tank not sub tank, so there is no issue with the upper control arm
1 - 5 of 5 Posts
