My GU TD42 started cranking slower & slower recently until it would no longer turn the motor over. Having done high km & with new batteries I suspected the starter. So I put in a new one & away we went for about a week. Then yesterday it stopped throwing back at all. It has full power to the motor itself but only 7.6V at the ignition wire when key fully turned. If I hotwire it directly to battery it turns over without issue.
I have a proximity immobilizer that is at least 6yrs old. It was in the car when I got it. I have been suspicious of this as part of the cause for some time now as it has been playing up a little recently.
My question is, could this be the issue?
I can't find a starter relay or solenoid anywhere. The starter has an internal earth & my batts/chassis/engine is well earthed. It has to be something like ignition switch, immobilizer, fuse, connection etc I would think.
Coincidentally this did happen the morning after a 4x4 river crossing. It started perfectly in the morning, then half an hr later it won't start at all. It has started once since & also last night something drained my battery & I had to jump start & then hotwire to get it going this morning. I use this car for work so I need to fix it asap. Any help or advice appreciated.
