1 - 20 of 20 Posts
So I've been researching LSD issues because I think mine doesn't work very well. I read that running engine oil flush through for 1000km might help, so I chucked in a 300mL bottle. 1000km later and still no better. When I jack up both rear wheels and try to spin one, they both spin in the same direction. From what I understand, this means that the LSD is working to some degree. However, if I jack just one of the wheels and put the vehicle in drive, the lifted wheel just spins freely with the grounded wheel not getting any traction.
So where to from here? Should I flush the diff, try another 1000km with EOF in it and then see if it's any better? Do I need to look at getting the diff rebuilt or shimmed?
GHMBC #3
nissan patrol gq lwb,3"lift.
after the 1000 km you did change oil didn't you?
Yeah its designed to have a variation of traction between the two wheels.
Not full traction on one and zero on the other.
It sounds as though, it is probably a little weak It should still try and drive the car off the jack to some degree.
Unless you are seriously struggling with traction issues I would just leave it alone. If you are struggling get a locker put in.
Yeah I changed the diff oil after the 1000km.
I was under the impression it should drive off the jack. Didn't realise it needed a bit of traction on both wheels. On the weekend I'll test it out on the tracks on the gravel and see if it spins both wheels in a low traction situation.
What oil are you using? I put penrite 140 Lim slip oil in and it seemed to make it tighter. done it for a few mates to and they have said the same
Sure does!! Mine binds up that much it's like it's a locker. Shudders the rear end a heap !
Discussion Starter · #11 ·
I used castrol diff oil that was recommended. I'll look at getting some of the ppenrite and changing to that over the weekend.
Run the straight 140 penrite.
I ran the 85/140 LSD Castrol for a while. The LSD never worked properly with the multigrade.
Sydoforumsuperfan :)
nissan gu patrol
This is from Castrol Datatek for the last 4.2 turbo patrols which is more updated
CASTROL AXLE LIMITED SLIP 90
Mineral gear oil recommended for cars and commercial vehicle axles operating under higher frictional loads, especially limited slip differentials and those experiencing clutch chatter. Meets Mack GO-J quality thermal stability requirement. SAE 90, API GL5
There's only about 200nm across the LSD and you can easily overcome that with your hands around a tyre...ie a lot less effort than it takes to move the patrol from rest. So you need to have some load on the opposite wheel for it to be effective. Just get on dirt and do a burn out..if it leaves dual tracks it working. It shouldn't shudder and but it should squeal on tight turns like underground concrete carparks.
Nissan patrol gq
try engage your parking brake while its on jack
if its working right it should send power to the other wheel
I think it's when you slightly press the brake pedal while driving it helps the LSD transfer the drive but not 100% sure. But as said just drop a wheelie in the mud with the misses standing behind your car to see what happens LOL
Discussion Starter · #18 ·
Apparently Penrite isn't making the limslip 140 anymore, they've replaced both limslip 140 and hypoid 140 with one product just called gear oil 140.
nissan gu patrol
Penrite and Castrol Datateck don't recommend 140 as diff oil in the last made TD42 Patrols as well as current ZD30's. Penrite are showing 80w-90. Reason ?
Discussion Starter · #20 ·
After dumping the diff oil on Sat and filling it with Penrite 140. Took it out for a spin on the soft sand yesterday and the LSD was spinning both wheels nicely. Now I just need to get my suspension sorted.
1 - 20 of 20 Posts
