i bought a lubricheck oiltester. i have used it to test both my diesel cars:
Note, both cars had the Delo400 and new filters changed in April 2014. Both cars had egr blocked.
I have Umoto drain valves installed on both cars, it make the access to the oil sample really easy.
Toyota turbo diesel 97 model, 3.0 has done 165,000km
Oil : Delo 400, [email protected], used for 9 months
Nissan ZD30 2006 model has done 105,400km
The little tester has 10 LEDs. the green ones means oil is in healthy condition, the orange led means the oil will coming up for a changes ( may be another 500km or more for example), and the red means need to change now.
Here are the test result:
Toyota: tester display a green bar 5 (which means oil is still in good condition, see photo attached)
Nissan: tester display a green bar 2 ( oil is in very good condition)
Looks like the ZD30Di is a much cleaner diesel engine ( especially with EGR blocked).
the oil in ZD30 also looks like near new condition, and the toyota oil looks quiet dark.
I believe previously we simply changed oil and filter too soon. and i was quiet concerned about the acid or other dirty things like soot, water, etc) before i carried out today's test. Since the tester manly check for all of these items. based on the result shows, i believe the Delo400 from new, is good for a 10,000km, 12 months in a healthy zd30 engine. compared to other part of the world, Australia's weather condition is very dry, so less likely the acid being build up that soon. i am going to to another test in a month time to see the condition of the oil, and eventually change both oils when they have reached 10,000kms or 12 months. The A$70 tester is a good investment.
So compare to the ZD30, the prado 97 diesel is an older design which need early oil changes. i think this also apply to some other older designed diesel engines like the TD4.2 which make sense to change oil much sooner compare to the zd30. But for zd30, with EGR disabled, we can make the oil change time extended.
the last photo shows the result from toyota oil test.
