1 - 10 of 10 Posts
Can anyone verify that the MAF Senser on Patrol models 2007 onwards are self cleaning by a surge around 15 volts during the service or done automatically?
I pull mine out and clean it. Just make sure the cleaner dries. I must have had a small amount of residue one day and the car rev'd a bit harder than normal when starting.
Never heard of self cleaning MAF, not unless they are introducing ultrasonics in somehow :). The stuff suggested works well, but I have been using CRC CO Contact Cleaner with good results for many years, I clean mine at each 10,000k service period whether it needs it or not.
Discussion Starter #7
MAF Sensor
When talking to Nissan Service I said that it was a bit smokey the other day and questioned whether it was a dirty MAF Sensor.
He said that it could have been dirty old fuel as the MAF Sensor is self cleaning on yours and later models
( Do they use a hot wire MAF Sensor ? )
Thanks.
Thanks.
I would have bet my house on the fact that it was a clueless Nissan Tech that sprouted this info at you.
Hot wire does not mean self cleaning.
The bubble and film type element used in the 01-03 is far more susceptible to failure due to dirt and contamination compared to the later model hot types.
Best piece of advice I can give you is NEVER go to nissan for vehicle servicing or repairs (unless it is under warranty repairs) Find a good local mechanic that is experienced in diesels and build a good rapport with them.
Your vehicle will be far better cared for and last alot longer than a dodgy dealer serviced car will.
Discussion Starter #9
MAF Sensor
I read somewhere that Bosch use a hot wire MAF using a self cleaning cycle with a platinum wire and heated to 1000 deg for a second after the engine is turned off to burn off contaminants controlled through the computer and a relay
I thought nissan might be using the same idea as I see there is an extra wire going to MAF on the later models
Looks like I am wrong.
Thanks for the info
A45 AMG, Ranger :(
Some MAF's do have a self cleaning function as above, but the GU's do not.
1 - 10 of 10 Posts
