Nissan patrol gr gr y61 3.0 Di 2001
Ciao
Io sono Antonio.
Puoi montare la Maf della zd30 dal 2004 a quella del 2001
Grazie
GUII ZD30DI Wgn
Ciao
Io sono Antonio.
Grazie
OK after translating to English
Hello I am antonio. You can mount the Maf of the zd30 from 2004 to 2001 Thank you
Not really, early ones are 4 wire 5 pin and the 2004 is 5 wire 6 pin. Do a search for "How to test all MAFs at home' it is located in the DI archives but maybe easier for you to do a search, it also explains the difference between MAFs.
[QUOTE = "Archem, post: 6996765, membro: 277365"]
Ciao
Io sono Antonio.
Grazie
[/ CITAZIONE]
