This electronic might be used on any car fitted with a vacuum actuator, a 12V Solenoid, and 5V max MAF / MAP.
I will deliver two units sometime in January to
@Bidja, and
@trev zd30 as they believed in what I was doing,and the reasons why I was doing it.
It can be used with the stock Solenoid, stock MAF, stock MAP, and stock actuator.
Knowing the obscene price of these Genuine nissan parts, I personnaly used
- a $50 brand new Pierburg N75 solenoid
- a $50 brand new Melett vacuum actuator
the stock MAF sensor, and the stock MAP sensor.
Of course, the ECU does not control the VNT anymore. The box does.
But the software can adapt to any MAF ( and correct its values to make it look like a genuine NISSAN MAF ), and any MAP.
For those who have a non-stock turbo, and mods allowing for boost in excess of what the standard MAP can accept ( + 1.5 bar or 21,7 psi ), you can use any MAP sensor providing you know what voltage it delivers for two points
( ex : the Nissan MAP delivers 0.5V for 133mbar absolute, and 4,5V for 2533mbar absolute ).
You'd better use an absolute sensor, as this will allow you to get your Patrol to behave as it should under very low pressure conditions ( i.e, at altitudes above 1500m). The magic box comes fitted with an accurate barometer, so you can see what you do.
Last but not least, yes any Patrol configuration can be handled.
if you have a remap and no limp, fine.
If you don't, the box makes use of RPM and MAF data to kill limps at all times. You can therefore tune in such a way to have good torque down low, and maximum air at all times.
It is your ECU which adds the fuel, in accordance with its own fueling maps.
When the ECU sees a given amount of air, it adds the quantity of fuel it has been instructed to.
More air in means more fuel added, means more power and better driveability.
Setting is as simple as filling up a turbo map using graphical aids.
The software runs on a PC, with Mac-OS or Windows.
It communicates wirelessly by bluetooth with the box. All settings are stored in EEPROM, so once set, you can just forget.
By setting accurately the vanes opening at all times, you'll be able to set, for example, the boost level you want when cruising on the highway.
Data recording and replay is also provided, at real-time speed, or higher speed to ease and speed-up data analysis graphically. You can also pause and go. go back and forward in the recorded file to identify the sequence of interest.
I haven't been able to think of anything else anyone would need. But happy to hear from any of you.
I have tested extensively all methods available, and even electronic controllers, and never found any which would do all what I wanted, and the right way.
So I did it.
