I'm very interested. So does this mean I can do my own Remap?
From what I understand I can tune the ZD30 as I go so this is better than a Remap.
Hey mate, did you get an answer on your question? Would like to know myselfWow!
How will it interact with cars that have been tuned? Will the average person be able to set it up themselves?
If you have understood thatHey mate, did you get an answer on your question? Would like to know myself
This sounds pretty easy Phil. I'm excitedly waiting in anticipation 👍If you have understood that
- controlling the solenoid accurately will control accurately the vanes opening, how fast the boost will build-up, and how high it will go.
- that at idle/low rev, the pwm value is too be set "high" to get the vanes pretty closed to ease the spinning
- that the vanes have to be then opened quite rapidly otherwise you build-up back-pressure, and the turbo spins too fast.
- if, at any point in time, vanes are too opened, then boost goes down, and so does the MAF value
- if, at any point in time, vanes are too closed, boost goes to the roof, but he MAF value does not increase as it should
- the best effieciency of the stock turbo is obtained when valves are half-closed ( or half-opened, same ) for OEM turbos, talk to your supplier. But you will find easily how they have to be managed to be the more efficient.
- When the boost gets close to the max you have decided, you need to open the vanes further.
Note: The full range of the Rod is roughly 10mm. The Nissan doc states that at idle, the pwm value applied is 55.9% to get the vanes fully closed, and the lever applying firmly on the limiting screw. At 20%pwm, the rod is fully down, and vanes fully opened.
So 36%pwm variation delivers a 10mm movement of the rod, ie 1% delta provides a 0.3mm movement.
An accuracy as little as 0.25% on the pwm control command provides an accuracy better than 0.1mm on the rod length / vanes position. And this is needed. Never forget the effect of 1/3rd of a turn on the limiting screw, or the rod length. It can be HUGE ! Hence the reason for very very accurate setting possibilities.
The MAP is 16 values long, each of them can be selected with an accuracy of 0.25%, from one end of the range to the other end. The software will interpolate values in between to get a very smooth control.
You are the one deciding to have, for instance
- 7 psi cruising at 80km/h, flat road, no wind
-11 psi cruising at 110km/h, flat road, no wind
- 18 psi max under load
Only one position of vanes opening at each boost level selected for a given cruising speed will provide the proper setting for any single car.
The documentation provided will explain in detail how to set these 16 values,once for all, in an arrangement suited to your car and your driving style. The box will come with a standard map, which you will adapt to your car and driving style with the aid of graphic tools.
To cut a long story short, the setting will be as simple as selecting a value with the arrow keys on a keyboard, and pressing "+" or '-' to increase, or decrease the boost level, and/or the vanes opening for a given boost level.
So yes, I believe anyone could set the system by himself, or otherwise ask some support from his friends...
Thanks mateWell done! Put me down on the list of the beta testers as well!!
Does a Navara zd have a variable vane turbo? I thought they had a standard wastegated turbo....The Navara with the ZD30 DI only runs a MAP sensor ,No MAF , will it work with them?
Swapped in a GTV 2360 with a bigger comp wheel. Run a dawes and needle currently.Does a Navara zd have a variable vane turbo? I thought they had a standard wastegated turbo....
Ease tell me more. I ha e a GT2052V and I've heard of this modification but I'm not clear on how to do it.Swapped in a GTV 2360 with a bigger comp wheel. Run a dawes and needle currently.
Sent the turbo to a company who supplied the bigger comp wheel and machine the compressor housing to match the comp wheel.Ease tell me more. I ha e a GT2052V and I've heard of this modification but I'm not clear on how to do it.
