Point taken and understood.
But let me disagree.
IF I reduce the MAF voltage by 0.3V (I used to do that in the past to kill limp), I loose a lot of power /Torque.
Since the ECM adds fuel wrt MAF voltage ( quantity of air), the equation less air + less fuel = less power was explainable.
I have therefore difficulties to follow you when you say MAF voltage is not that important, and that I would not see any difference on a dyno.
I am using no remap, the stock fuel table and AFR.
I can drive up in steep mountains in 5th gear whilst in the past I had to go 4. There must be a difference therefore.
And everybody running an MB have shared the same positive experience.
Why would engineers design a clever vanes system for turbo to adjust the flow if a two stage turbo ( vanes fully closed or fully open ) provide the same result. Hard to believe. I can't follow you on that one.
What is sure is that as long as you keep the vanes aroiund 1/2 open ( or 1/2 close) more or less, it is the area where the VNT is the most efficient. Valves do not allow that. This is in open litterature on the subject, and it is what I have experienced.
Last point, @Bidja improved the timing of his runs. another point nobody can deny. why for if not for additional air provided by better vanes management ?
I am not a dreamer, nor a liar unlike some people would like others to believe. just sharing what I have seen, measured, and learnt "on the field".
If I were close to your place, I would love to work a few hours on this very subject with you, and any VNT on any car.
