Manual gearbox - ls1 patrol
1 reading
7.6K views 8 replies 4 participants last post by  simcoe
Hey guys I'm after some opinions please.
I have a 5 speed manual box in my 2000 model gu at the moment which is on its last legs and needs a rebuild. I have converted from the zd30 grenade to an ls1 and would like to know which option would be better long term.
First idea : rebuild my current zd30 box and install the bigger/stronger 5th gear. Was also going to install the marks adapters 5 th gear over drive ratios.... Currently the car sits on 2600-2700 rpm at 100km/hr.
Second idea : remove my zd box and purchase a second hand 4.8 petrol gu box which would already have bigger/stronger 5th gear. I've also been told the 4.8 boxes have a lower 5th gear ratio...... Which would save me buying the marks adapters ratios for the zd box.
Which option do you guys recommend. I am in no way looking at building a race truck, just want a solid reliable gearbox more suited to touring and towing a van.
Cheers guys
#2 ·
Diff ratios will sort the highway revs out. 3.0 will have 4.3. Get some 3.9 or 4.1's.
Just grab an 02 box out of any variant and swap it out as the 5th had been sorted by then.
A few guys have marks od 5th and like it. A lot of coin though!
#7 ·
That's off the marks site I could find the ratio chart, but there is a good diff ratio tyre size calculator in the technical section
I found this in another thread
Y61 Transmission Ratio’s as follows:
3.0 and 4.2 manual gearbox ratios = 1st 4.262, 2nd 2.455, 3rd 1.488, 4th 1.000, 5th 0.850, rev 3.971.
4.8 manual gearbox ratios = 1st 4.085, 2nd 2.353, 3rd 1.426, 4th 1.000, 5th 0.881, rev 3.806.
3.0 auto gearbox ratios = 1st 2.784, 2nd 1.544, 3rd 1.000, 4th 0.694, rev 2.275.
4.8 auto gearbox ratios = 1st 3.540, 2nd 2.264, 3rd 1.471, 4th 1.000, 5th 0.834, rev 2.370.
Transfer case ratios = high 1:1, low 2.02:1.
#8 ·
There are 2 versions of the gu 42 box. The one above, is as fitted to turbo coil cabs both dx and St.
Leaf versions and the odd non turbo coil cab have lower ratio first to third with a .836 fifth.
Same ratios as qg boxes.
Tb45 have a 91 overdrive from memory.
You can use the gq 5the in a gu box, just need to machine a spacer to fit between 5th, the the gu spacer, and the bearing to set snap ring gap.
Or you can, as my box uses, mix and match qg and gu internals in the gu case.
#9 ·
I can't for the life of me find where I read this but the crd manual box im throwing in my 99 dual cab td42t has a shorter first.
I believe the factory TD turbs wagon has the tall first while Utes/na wagon had the short first.
