1 - 17 of 17 Posts
nissan gq patrol
54-59nm for the manual ones and 54-64nm for the auto.
cheers,
sloth.
Come on Benno stop stuffing around & rattle them up till they strip & then just back them off a fraction :)
Haven't you downloaded the genuine GU manual yet
Regards Don
A forman i used to work with use to say that every apprentice should have two sets of tools
One set with long handles to undo thing with as the the can never get anything undone &
a second set with short handles to do things up with as they always overtighten & strip them
Regards Don
I have a genuine GU manual on my other computer that is currently dead, the voltage converter died :(
Whilst your all here, Im doing the manual conversion, coorect me where wrong.
Remove snap ring, remove two spacers, egg ring in, then lipped ring with the lip on the inner side, drive cog, snap ring, hub in, tighten bolts
Put on with the hub on free or lock?
Sorry cant help with this i haven't done the conversion as DX's come with manuals as standard
With toyota's the hubs go back on in the free position (as long as you line them up correctly on assembly)
Does this help
Regards Don
Discussion Starter · #13 ·
Freaking awesome mate, just for the record what I wrote above is the correct procedure.
:cheers:
Forgot my circlip pliers, thier at work, so its a tomorrow arvy job. I wasnt planning on fitting them so early but I got to go pick up a project car on friday and the dude Im buying it off lives on a hill that makes everest look flat.... so with the 2.8s torque band I need some lower gearing.
:cheers:
If you ask nicely someone with a TD42 & a towbar would probably pick it up for you :p
Regards Don
Oh dear Don don't go down that road!
Could open up a can of worms.
On a side note it must be really steep if Benno is admitting to needing more torque.
Justin
Discussion Starter · #16 ·
Ha ha, as ethanboris says "I kill you". :)
Apart from this dudes driveway theres alot of bloody stop signs right on the crest of really steep hills so its easier for everyone I think if I just leave the truck in low range 2wd until I hit flat lands again.
2.8 doesnt have a torque problem, just they left the 18spd road ranger out on the production line.......
When you get brand spanker new hubs sets too the egg ring is lightly pressed into the back of the hub to keeep all the rollers in there, just to fark with your head a little more.
Discussion Starter · #17 · (Edited)
Well they are all in now, whole 10 min job per side once the snap ring was off. Light smear of Castrol HTB over most parts and they just fell in. Got SWMBO to hold the brakes on so I could torque the hub bolts and wheel nuts :)
She didnt get the all clear hands in the air F1 style act before I dropped it off the jack at the time but she did in the end ;)
To make it easier to fit the spacer and egg rings they spent the day in the freezer, only the lightest taps with a soft mallet to seat them home.
Thanks again Don.
1 - 17 of 17 Posts
