Hey all, I'm just looking for some info about the SD33T's stock mechanical lift pump, TD owners input would also be appreciated as I'd say the specs would be about the same.
As I've mentioned in a few threads before, my SD33T has had the mechanical lift pump removed from the injector pump, and I'm running a holley blue fuel pump and pressure regulator to feed fuel to the system.
I just was wondering what kind of pressure the mechanical lift pump would usually supply to the injector pump, so I know what pressure to set the regulator to?
Usually when you've got an electric fuel pump, you've also got the mechanical one as well, so you don't need to run much pressure, but since I don't have the mechanical one, I need to run the same or more pressure than it would produce.
Thanks
Thanks
