1 - 14 of 14 Posts
· KICKEN BACK IN THE BUSH
MK range had a SD33 Turbo from the factory
Track one down and rob all the bits and whack on yours
Do a bitta reading theres just heaps on here regarding this conversion
you see them on ebay and what not sometimes a whole car from 500 to 100 dollars. buy one of them and just throw the whole motor and box it and be done with it. Add a straight through exhaust. front mount cooler, pyro gauge, wind up the fuel and your done.
Yeah a 2nd handie SD33T can be had for cheap,if ya can find them
2nd hand Turbo and manifolds change hands around the $400-$500 alone
Many members on here have sold gear around that $$$
neRoK,
Yeah extractors for the n/a had a chuckle meself
But crank some fuel,adjust the IP and timing extractors and bigger zorst,
I reckon youd get more poke from the n/a
HHMM,
I can get a set of extractors for the SD i wonder,should i play HHHMMM
piece of cake.
Or add nitrous.:naughty:
@nerok, got any pix on those extractors?
thanks mate, would apreciate a pic of extractors for the sd33.
I want to throw an sd33 n/a in my L60 and a bit more horses would be a pleasant plus.
don't want to turbo it.
I wonder if I've got extractors on my N/A then?!? Will jump down on my lunch break and snap a photo
Yep thats them extractors
Just on a note:
Now an old motorbike trick with the 2 piece headers (never seen a pair on an SD tho)
Just thought id mention it while where on exhaust
You run two single out let pipes of the headers (two piece headers,two pipes)then spray with paint
Run till hot,where the paint stops peeling thats where you cut and join them together
Tuned length i think its called
Just a handy tip for maybe something else ???
Exhausts well theres many mods that can give more/better power
Ceramic coating helps,heat bandage (although now considered old school) still work
Snorkels help, just so many little things to help with more squirt
Equal lengts tubes wich are long help for better low down torque. Not to big tubes too.
1 - 14 of 14 Posts
