well!, 35's are the start of your powerless truck!
they do have the most horses at the rear wheels of all the GQ's tho!!
being on gas is even wors!
get some headers (if you haven't allready got them) and electr. ignition (if you have the carby tb42)
and go to a gas specialist WITH A DYNO!!!! that's the only way to get the most out of your gas fed engine!
other more expensive options are reduction gears in your transfercase as you are running 35's.
i run 33" tyres and is ok allround, anything bigger needs some more $$$ spend on it! , like i said, reduction in the transfer or the diffs to bring it back to original torque!
or if you have the tb42e you just bolt on a wizzer!
