need a bit of help here from the guru's . just went out to start the patrol , waited till engine had heated turned the key and nothing . dash lights didn't dim checked battery and all fine there.havent had any trouble before only thing i did do was put the auto in reverse with ignition on this morning to fix the reverse light . checked fault codes and none as well as obvious fuses ,, so what could it be ?
