1 - 5 of 5 Posts
Hey everyone,
I'm looking at buying an RFI phone aerial. I have an ARB bullbar (winch bar if that helps) on my 00' GU. The welded bracket that come with the bar (on the left) already has a UHF aerial mounted to it. I want to add a bracket to the left of this.
Can anyone recommend a suitable bolt on bracket they've used from GME or somewhere else?
Thanks in advance
Cheers for the reply.
Does anyone know the correct size for an ARB bar (the top piece of tube)? Just don't currently have access to the vehicle.
Thanks
47.5mm. ARB also have a clamp on bracket to suit. It's powder coated black like the bar for a perfect match. The GME ones work well, but look out of place on a powder coated bar. Although your bar should already come with a second aerial tab?
Thanks for the measurement! Will definitely look into the ARB one.
The bar has a second aerial tab however mounting it in this spot will mean it will be right in front of me blocking my driving vision (little bit annoying).
Thanks
1 - 5 of 5 Posts
