1 - 1 of 1 Posts
Gday,
I have owned my RX GQ 2.8 patrol now for 4-5 years and have recently started modifying it and would like to share some photos of the car. All work/modifications were carried out by myself and are- 3inch lift 7 inch rear shocks 6 inch front shocks 15mm spring spacers in the rear superior upper and lower trailing arms fixed length, 3 inch caster correction bushes in front arms, superior fixed length 3 inch panhard rods, adjustable steering link, 3 inch exhaust safari snorkel kit with replacement airbox modified fuel pump timing 12psi with pressure relief valve deleted, 33x12.5 Federal couragias -22 sunraisers, dual batteries using piranha tray and red arc solenoid with wiring to rear, custom rear panels (made to increase strength) to house switches and power outlets, False floor with fridge slide mounted to it, custom made rear light bracket, projecta 350w inverter in behind right hand rear panel, GME4500 uhf.
1 - 1 of 1 Posts
