Patrol went to my regular mechanics for a service yesterday.
Replaced the clutch hydraulics and adjusted the valve clearances. Inlets were fine, exhaust had closed up a bit.
Anyway, the idle is so much smoother now and the old td42 seems to pull better.
Now that the tappets are sorted out, I'm free to install the heat exchanger for the W2A intercooler.
My original plan was to do the intercooler then think about a turbo upgrade later because the existing Safari turbo "ain't broken"
BUT.
Doing the intercooler before the turbo seems back to front.
Perhaps I should work on the bottom of the engine bay before I start adding stuff to the top...
Also, I've become the proud owner of a little Mamba TD05/16G.
Also, I'd like to drill the exhaust manifold for an intercooler bracket.
There's already undrilled bosses on that manifold, I'm guessing for a heat shield that was never fitted.
Those bosses would be nicely placed for an intercooler support bracket.
If I'm careful I can probably drill and tap blind holes in those bosses.
I'd also like to add sensors to the exhaust manifold, for pre turbo EGT and perhaps EMP. More drilling and tapping.
Looking at other posts on this forum, it seems
@OldMav and
@bambill think the old Safari manifold is ok.
It's a pre-EGR design, so it's nice and simple.
The flange looks like it'll match the Mamba TD05. I still need to verify the flange angle is sufficient for the TD05 to clear the block.
The Safari manifold is also divided front from back. In fact I've seen the Safari manifold mentioned as a good match for a dual-scroll turbo. That's beyond my scope though.
I think Oldmav mentioned somewhere that a bit of die grinding would help the Safari manifold, I'm not sure where, was it the divider at the turbo flange or was it exhaust port matching?
Anyway. That's my thoughts. Turbo upgrade before intercooler. Saves removing then replacing the intercooler twice.
