1 - 5 of 5 Posts
Nissan SWB Y61/Model 2006/TB45E Engine
Hello Guys
I would like to inquire about all kinds of lubricants that I should use for my Nissan Patrol 2006/TB45E/Manual Transmission with 270,000 KM mileage,
I'm currently located in Saudi Arabia thus the elevated temperature, therefore i would like to know what are the best specifications of lubricants for each part on my vehicle.
Example:
  • Engine Oil,
  • Rear Diff Oil(without LSD),
  • Front Diff Oil
  • Transfer Case
  • Manual Transmission
Appreciate your prompt feedback.
Thank you ❤
Hey mate this is for a TD42 diesel but everything except the engine should be the same
Transfer case 1.9 litres
- auto transfluid
Rear diff 2.1 - 4.5 litres
- limited slip 140
Front diff 5.4 litres
- 80w90 gear oil
Gearbox 3.8 litres
- Pro gear 75w85 GL4 or ATF
Engine 10.5 litres (+1L from oil bypass 11.5 total)
- 15w40 semi synthetic
Hello mate,thanks for your reply.
Did you take in to consideration my hot area? Or i doesnt matter with the gear oil?
And two other notes please,
First my rear diff is not a LSD axle
ATF dex3 or 6 need?
Thanks.❤
1999 GU Wagon ST RD28
ATF dex3 or 6 need?
Thanks.❤
I doubt Saudi Arabia gets any hotter than Australia. Open diff can use LSD oil no problem
1 - 5 of 5 Posts
