Thanks mate. I figured it was a data link(ie unable to replicate inputs or trick the TCU into thinking there's a ECU connected)No, it can't. If the data communication wires aren't there, it goes into limp.
The TB45E auto ECU was designed to retard the ignition at each up shift so it's seen as a fault if it can't communicate.
To the best of my knowledge, there is no auto ECU/TCU combo for the TD42Ti.
You can use the TCU from a TB42 or TD42.
I guess I'm just looking for a TCU that doesn't require an ECU. TB42 and TD42 the only options? What about TB42e?
Cheers,
Doc
