Let me pre fix this with; yes i have used the search function a bunch and done a lot of reading and researching but sometimes you just need to ask the question yourself to get the answers you're looking for.
So, Do i really need to do the NADS mods on my 2012 GU? It's done about 65K clicks, doesnt blow any smoke and runs quite smoothly.
I don't like messing around with modern engines too much and would hate to try and do something to benefit the engine that ends up hurting it because i've done it wrong.
The only part of the NADS i have seriously considered is the EGR block with a hole drilled in it of course as mine is the CRD. But even this I'm skeptical about as i would then have to get a scangauge just in case it starts going in to limp mode and i need to clear fault codes.
The daws and needle is too finicky of a job for me i think and a lot of the info i have read just confused me. The mechanical knowledge i have is simple old school piston engines and big turbine aircraft engines so stuffing around with delicate boost voltage settings will just stress me out more then anything haha. (I'm more of a mallet man rather then a scalpel man)
So I'm just looking for a simple to understand no bull answer. If i look after my Patrol and drive it like its supposed to be driven, will everything be ok or will it spontaneously combust like a lot of the info on here suggests?
