Have a g60 that seems to run fine once running but if the car doesn't continue to run on first fire I have to crank it over for ages to get it to fire, is it the plugs leads or the carby
Please check www.rmp-o.com
We need more information ?
1- Are you running clean fuel ? disconnect the fuel line from the fuel pump and run direct into a can. Many G60's have rusty old tanks
2- With spark plugs removed are you getting fuel mist when car is cranked
3- Rem,ove each spark plug and earth against engine, when cranked can you see the blue spark at each spark plug
4- Is the dizzy vacum advance air line connected from the dizzy to the carbie
5- Did the car run correctly before or is this the 1st time you are getting it running
6 - PHOTOS
7- Where u located :)
Thanks
Steve
Thanks for the replies, the car was running fine about a month ago but you might be right about the tank because it did get blocked and I drained the tank, it does have two tanks I might connect and use the other tank and I'm located in Vic
