1 - 20 of 21 Posts
What Have I Done?
Howdy fellas,
im, at some stage this year going to get a car lift, for personal use at home...
as there is a number of different types that are available,
ie 4 post,
2 post,
2 post short height type,
2 post movable type,
scissor lift 2 types - one with ramps ,
and one without.
now my dilemma is,
the roof in my garage is 3meters high,
yet I have a panel lift door which would most certainly get in my way with a 2 poster
and with a 4 poster, I'd be left with no room at the front of my car...
So between the two type of scissor lifts available,
can you guys please give me your opinions, for and against etc
these are the two im debating between bellow,.
please if anyone uses any or both, do share your opinion,
ie, versatility, strength, lift strength etc etc etc.... and stability
only gonna use for for sedans
thanks guys.... titties later !!
ps. top 3 pics are the ramp style that you drive over etc...
What Have I Done?
lift car to service fully ( have big volume sump pan, too low atm to even get high enough with a jack ffs)
brakes, steering, tailshaft re balanced, diff centre gear change, suspention upgrade in the rear ( leaf Sprung atm)
exhaust mod.
and overall, interior work but would like to be standing while I work on it from the outside.
ohh and need to change oil pan fkn seal, ( real pitta to do while its on the ground.)
I know I can just take it to someone to do all this,
but I like to do these kind of things myself,
and a lift will be a great addition to my tools and help me immensely .
ps, theyre fkn cheap enough now, they used to be like round 4k, now you can find em round the 1.5k ! WOW !
GU IV 4.2
Personally for me the scissor lift type only really seem to be useful for tyre changes and the like. Just not enough room to get underneath and do work, and also don't think they really lift high enough to get under.
Personally I'll be going for a 2 poster when I do it, however space won't be an issue for me.
im always thinking of the safety features these products may or may not have.
Do you "lock it in" once elevated? If a hose blew or something silly will it come crashing to the ground?
They do look pretty handy. Sure beats crawling around on the floor.
Just looked on ebay. These seem to be the same sort of price as the 2 posters, but if you don't have the height I guess your options are limited.
What Have I Done?
Discussion Starter #7
yeah I concur re safety etc , and yes they do lock..
get out the concrete cutter and do a pit then. can be covered when not in use and gives you better access underneath when doing repairs than those other lifts you showed.
Also seens space is an issue if gives you an area to keep your oils/spares/spiders etc
What Have I Done?
Discussion Starter #12
understood, yet hoist is the question, if I built the house I would have inbuilt a scissor lift..
like this bellow...
a pit doesn't get my wheels off the ground, and the expense and trouble to safetyfy the area when the car is out, would be a pain...
GU IV 4.2
I just don't think scissors or short 2 post is really worth it because you can't get under it and stand up to do the work.
As far as safety goes any hydraulic hoist either the scissor style or 2 or 4 post should have a safety catch on them to lock in when your using them
Here you go.
Portable two poster, tuck it away when not needed. Will fit under a low ceiling. Can sit on a stool while tinkering underneath your car. Happy days.
Aussie price a little more I guess.
Dannmar Maxjax Portable 2 Post Car Lift 6 000 lb Capacity | eBay
These do seem a little more practical than the scissor type. Once some hd fixings are fitted in your slab, at least they will be akin to every other 2 poster out there.
You have a real dilema LJ!
No easy answers.
I think 2 post is the best choice but height will be a problem.
I'm going 2 post but the shed will be 5.2m high.
Pit in the ground and jack stands for wheel work maybe the only compromise.
Justin
Decent set of jack stands is just as good as that if not better as you can work with the wheels off.
Real handy if pulling a diff centre out too.
Justin
sissor lifts are all but useless for anything more than wheel brake and some suspension work.
outside of that better off on the floor.
2 poster is what you want but i reckon u need more than 3m ceiling.
1 - 20 of 21 Posts
