1 - 7 of 7 Posts
Hey
I'm Sultan from Saudi Arabia
Today I got Patrol Y60 SWB 1991. I just need from your experience suggestions to improve the power of the engine .
Waiting for your respond
cmon , you all were thinking it!
If you ARE a sultan , i suggest you fly me over to your wonderful country on a all expensives
paid trip , were I can look at this gutless boat anchor in person, and advise you from there!
however if your a bloke CALLED sultan, then use the search function , Im off to check my lotto tickets.
just a good guy.
2009 gu ute
ah here we go again. IS IT PETROL OR DIESEL:loser: AND WHAT SIZE ENGINE
When I got the car I installed
MSD 8202 Blaster 2 Hi-Performance Coil
MSD 8214 Ballast Coil Resistor
NGK (8105) NE61 Spark Plug Wire Set
NGK (6637) BPR6EIX Iridium IX Spark Plug
Spectre Performance 9732 Air Filter
it's cost me around 200$ and I found good preference
after a while I face a problems with nissan Carby and I change the carb to Edelbrock 1406 600cfm and I got a lot of black smoke without deference
now I'll install fuel regulator to control the fuel that goes to the carb because I feel there are a lot of fuel goes to the carb and the Edelbrock 1406 600cfm need 6 psi fuel pressure
anyway that was my story with Y60 TB42 Carb
Now I'm Planing to turbo the Engine so what is your advice ?
I would go EFI with an aftermarket programmable ECU, much easier these days to find a tuner to dial it in than trying to tune a blow through turbo carby setup. It will cost more but will be a much better setup
thank for your advice
Do you prefer a EFI product that have good preference
I find on ebay IMPCO PROPANE FORKLIFT CONVERSION FOR NISSAN TB42 and what do you think about it ?
Complete IMPCO Propane Forklift Conversion for Nissan TB42 Fork Lift BF05A70V | eBay
1 - 7 of 7 Posts
