1 - 9 of 9 Posts
its time for a new clutch what would you guys recomend it's a 90 mod 4.2 patrol/gas.
Just did ours, original lasted 417k kms, $1500 all up. Terrain tamer heavy duty, flywheel machined and rear oil seal replaced while box was out.
Nissan patrol
safari tough clutch. Make sure you get the bush for the input shaft etc. may as well do the rear main, just in case.
I bought one once which I think was a Clutch Industries one for $200. It did the job and the price was excellent. I don't own the truck anymore so I don't know how long it will last.
I think a genuine one was about $280 at the time.
while they are doing the rear engine seal, get them to check/replace welch plugs on the back of the engine, inside the bellhousing (gearbox shroud from engine). this may save leaky coolant fluid later on. i just had my clutch done too. $600 for the exedy (aka. Daikin) safari, with around $600 for labour, and new PBR master cyl and slave cyls $280...i think. all up, just shy of $1500...WELL worth it, it drives sooo sweetly now!!!
I fitted the PBR 4Terrain kit in mine very happy with it cost $440.00 for the kit. That includes throw out race clutch and pressure plate.
The flywheel resurface was $80. Fitted new spigot bearing cannot remember how much and all new welsh plugs at back of motor, I forgot to do oil seal but it hasn't leaked yet but I would advise to do it.
I also fitted new slave cylinder but used original master cylinder.
1 - 9 of 9 Posts
