1 - 20 of 306 Posts
Hi everybody
First, let me just tell you that I'm not speaking english as good as I would like... I'm living in Switzerland, and my mothertongue is french. I will try my best to make you undersand what I want to share with you. Thank you guys in advance for your keen indulgence.
I run a 4x4 equipment shop here in Switerland. Beside this activity, We also run an adventure travel company. We are organising 4x4 trips from Switzerland / France / Germany to different destinations as Iceland, Russia, Romania, Sahara. We also have central Asia in the pipeline (Mongolia, Kirghiztan...)
Back to the vehicle. I bought the new Patrol 3.0 crd in 2012, but it's a 2007 with about 40'000 ks on the clock. It will be one of our organisation vehicle that lead or end the convoy. I also have an old 93 HDJ80 wich burned its 3rd auto trans...
My first wish (dream), was to put a 6.5 TD V8 in the patrol. But for homologation reasons, that was impossible. I had to get a descent power out of the little 3.0 crd... I can say now that I'm very happy with the result.
This is an overview of what I did to it:
- BF GOODRICH mud-terrain 37 x 12,5 R17
- Lovells coils +10cm front / +15 cm rear. -> need to put some +5" HD in the front
- 2,5" King shocks with reservoir
- Front shocks mounts redesigned
- reinforced rear coils seats
- Caster plates -> need to put some drop boxes instead.
- Front & rear Panhards from Superior Engineering
- Upper and lower rear trailing arms from Superior Engnineering
- Front disconnect from Superior Engineering (not happy)
- rear longer electronic disconnect
- Stainless steel HD brake lines
- front Thoug Dog RTC
- front & rear limiting straps
- 4.88:1 rings & pinion
- ARB front locker + rear original Nissan electric locker
- MasterTEC -48% lower ratio (final: 2,99:1)
- MantaPRO 3" exhaust with sport cat.
- Cross-country big intercooler + fan with thermostat
- power module
- dawes setup
- Provent 200 oil separator
- Separ2000 fuel separator with filter + collecting bowl
- EGR blanking
- snorkel
- 2x Odyssey 1750 / 930CCA with IBS coupler / separator
- solid ACS flywheel
- Heavy-duty ACS clutch
- MasterTEC front winch bumper with recovery points + lights
- MasterTEC Platinum 12000 FGS winch with corde dyneema rope (30m)
- MasterTEC rear bumper with 1 spare wheel carrier + recovery points
- Front and under protection made in Polyethylen PE-HD 10mm
- Front axle housing
- rear 3rd member and diff skid plate made of PE-HD 10mm
- rear shocks protection plates made of PE-HD
- Rigid Industries 50cm led bar (6400 lumen)
- 2 x Rigid Industries Dually D2 led spot (2x 2600 lumen)
- 2 x Rigid Industries Flood spots for rear and camp (2x 1300 lumen)
- Front-Runner expedition roof rack (280x140cm)
- 130x90cm roof plastic box for light items (chairs, sleeping bags, shoes...)
- MasterCAMP roof top tent (140x240) with big room (300x200cm)
- MasterCAMP Giant270 awning
- MasterCAMP 45 liters fridge
- rear rack for RAKO boxes
- Outback roof console
- Midland CB, Icom VHF/UHF
- Asus tab for nav
- boost + EGT gauges
- ScanGauge II
Some photos will follow. Thank you for reading / watching. I learned a lot of things about the crd on this forum. People are passionnate and happy to share passion and informations. Thank you everybody for this. Don't hesitate to ask if you have any question about our vehicle. I will be more than happy to answer.
Nicolas
Discussion Starter · #2 · (Edited)
General photos
Discussion Starter · #3 · (Edited)
Some more, taken during a tour in the Alps to test the girl... 2800 m above sea level.
Discussion Starter · #4 · (Edited)
Some more photos taken up in the mountains, in one of my favourite place.
Hope you appreciate. I still have a lot of pic of the complete build-up or details of the products that we fitted on the vehicle. I don't know if that interest you... just let me know ;)
Cheers from switzerland
Nicolas
Really impressive mate! Your english is quite good too, I am very curious about the PE-HD skid plates, that is not something I have ever seen or heard of before. Why did you do it like that? To save weight? or corrosion reasons?
Keep the pictures coming!
Craig
Discussion Starter · #8 · (Edited)
Hi Craig. Thanks for your nice comment.
I found the PE-HD very light, easy to work on (use of an air heater to bend a plate), and most important: indestructible. This material is also perfect in case of an hard contact as it return to its original shape. So, no contact, vibration and abrasion with another part possible after an impact. Some details below...
Discussion Starter · #12 ·
Hi Isack
MasterTECH is our own brand. You will not find it on the net as it's not widely distributed... yet. ;-)
The bars are manufactured in Europa, not in China. Made of galvanized 4mm steel. Very strong.
Nico
Discussion Starter · #14 · (Edited)
Some more details of this preparation
- Front shocks + straps
- Upper supports
- Rear coils seats reinforcement
- 4.88:1 vs 4.11:1 comparo
- original dump pipe/cata vs new MantaPro dump/sport cat
More to come if you like. Cheers.
Nico
· Premium Member
1995 GQ TD42 NA
Welcome to the forum!
What a brilliantly set-up Patrol, certainly one of the best I've seen. Love the PE-HD protection plates!
Yes please to more info on the build up :)
· Rogue
22' Ranger Raptor V6TT
That has got to be my most favourite Patrol! What a rig, that is awesome!
Very nice innovation with the products too!
1 - 20 of 306 Posts
