1 - 5 of 5 Posts
nissan patrol gu 4x4
Have been in and around Brisbane for the last week and have spent a couple of dollars on some goodies.
Bought a 3" Scott's Rod's exhaust
Bought Airbag Man rear airbags
Got to find a Koni shock retailer on monday
Gunna fit up the air bags and exhaust on sunday afternoon.
Will be interesting to see and feel the difference on the way home next friday
Currently in PAD rehab
Very cool, congrats! Sounds like its going to be a beast!
Cant see it in your sig, but do you have a diesel or petrol? Just curious if you have the dawes/needle valves in before putting the exhaust on..
Sounds like you are going to be busy!
Yeah ZD30 dronus, already have Dawes and needle. Max's out at about 15psi and sat on about 11/12psi from Mount Isa to Brisbane. also EGR blocked. EGT are about 275 cruising at 110kph on flat road.
I suppose I will have to make some adjustments after fitting exhaust.
Forgot to mention , New roof rack too
Greetings,
FirstGU, are you getting it tuned in Brissy before that long drive back to the Isa?
or is there a good dyno/tuner operator in the Isa now?
truck
Not sure if you have already entered your details in the ZD30 EGT survey below, if you have great, and please update when you get your new gear on. You can never have too much information.
Hope it goes well for you.
http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/egt-temp-survey-52005/
1 - 5 of 5 Posts
