1 - 5 of 5 Posts
I noticed a problem lately with our bnew 3 month old GU with the zd30di engine. Auto tranny would sometimes take some time to shift up from 1st to 2nd gear. RPMs have to occasionally rev up all the way to 3k or even 4 or 5k just for it to shift up. This happens occasionally only. Rig is driven on level ground with no inclines. Before, a slight easing up of the foot on the accelerator wouls cause the tranny to shift up already No towing. Would a recent install of the Steinbauer affect tranny shifting behaviour? Any ideas? Thanks in advance.
Autos are Superior
remove steinbauer and try again.
Turned off already the steinbauer switch. Problem persists. Would resetting the ecu help?
nissan patrol gu
disconnect battery for half hour and take for reasonable drive as u would drive it normally. don't granny drive it. ecu needs to relearn ur driving style... all the best
Just to update this thread. Did an ecu reset. Problem appears to have disappeared, hopefully. Thanks.
1 - 5 of 5 Posts
