21 - 31 of 31 Posts
Discussion Starter · #21 ·
If the data set used the same formatting protocol, then yes. But I don't have a view of Nissan's coding logic. So although the underlying data is a simple .csv, depending on how they wrote it, depends on if the system will read it correctly.
For e.g
Car maker 1 codes an address like this: 123 Imlost Drive
X co-ord xx:yy:zz
Y co-ord xx:yy:xx
Supplementary data" Show text "Imlost Drive"
In the actual data set, it may look like this
X=xxxxxxxx
Y=xxxxxxxx
Supp="Imlost Drive"
Car maker 2 codes the same address like this: 123 Imlost Drive
X=xxxxxxxx; Y=xxxxxxxx; Supp="text"
See that semi-colon between the pieces of identical data? That's enough to render the data unreadable by another system.
Discussion Starter · #22 ·
I have to laugh, so I got the new card, plugged it in and.....yip, EXACTLY the same as the old one. I have asked Nissan ****sville to explain.
Discussion Starter · #23 ·
So I have asked Nissan Australia four (4) times WHAT has changed. This is the reply. Ludicrous.
Reply 1"As your email was in regards to updates for your navigation system, the update we are discussing is in regards to this feature. We sincerely apologise for not being able to meet your expectations in relation to your concern. Kind regards,"
And this reply 2, "Thank you for your email. As stated below, the SD card you have in your vehicle is an update, and the one you have is the latest SD card available. As soon as there is another update, you will be made aware at the following service after release. Nissan Australia apologises for any inconvenience this may cause.Kind regards,"
Nissan 2006 model ute
Just heard new maps are available.
Discussion Starter · #25 ·
The maps are not new, thats 20170403, 501 maps. They cannot even tell me what has changed.
nissan patrol gq
Are these just “standard” SD cards?
I guess the real question is “will I kill the card putting it in a PC Card reader?”
I want to do some digging/updating if I can access the card.
I deal with some industrial gear that standard looking cards are not actually standard and a PC Card reader will kill them.
Discussion Starter · #28 ·
Do 2 things mate,
Make a copy when you read the card, then play with a copy of that copy. No issues. And yes play as much as you like.
nissan patrol gq
Do 2 things mate,
That’s what I was going to do. More just the hardware question. Don’t want to kill something.
I normally use full byte wise imaging for backups of this sort of thing too.
Discussion Starter · #30 ·
You cant kill it matey - have at it!
Discussion Starter · #31 ·
This from Nissan today.
Thank you for contacting Nissan Motor Co in relation to your enquiry.
The next map update for your Y62 vehicle is due to be released this quarter of the year however, unfortunately we are unable to confirm an ETA. At this stage, it is in processing status. Once there is an update, it will be advised.
Nissan Australia sincerely apologises for any inconvenience cause.
Kind regards,
Olevia
Customer Service Consultant – Customer Service Centre Customer Experience Department
Nissan Motor Co. (Australia) Pty. Ltd.
Phone: 1800 035 035
21 - 31 of 31 Posts
