Well today I got the grinder out to clear some bog and check the roof rust to make sure it's repairable, I have already decided if I cant fix the roof I would likely try to find another body for 6months and if I didn't have any luck I would wreck her, something I really want to avoid.
So far the passenger side looks salvageable, the out shell and middle section have some bad spots, but most I can cut out and weld in new sections. As is typical, it has rusted at the spot welds and joins. Luckily the inner shell has nothing more than a couple spots of surface rust. Fingers crossed the other side is similar, but it does look a tad worse from the outside.
So far I will need to replace both front outer guards, and probably doors too as they are rusted badly at the hinges. I know that GQ front doors fit, does anyone know if the guards and rear doors fit from a GQ?
Chassis looks great, hardly any rust besides some minor surface stuff. She has had a pretty bad oil leak from the oil filter housing which coated pretty much the entire underbody. Degreased all that and still happy with how she looks underneath.
Also found the glow plug timer is no longer there and the relay is cactus (plus a **** load of other dodgy wiring), for a temporary measure I chucked in an isolator between the + and - for the glow plug connection so I can flick it on for 30seconds if I have to move her.
