Control panel located between the two front seats.
By pressing the "power" switch, both USB (actually four - 2x 2.5A and 2x 5A) plugs get power, and you can also monitoring the voltage in the auxlilary battery on the screen.
All additional consumers in car are tied to a secondary auxlilary battery ... More on that in another topic
By pressing the interior lights switch, we control the the drawer lighting. ON/OFF
We also took care of the ambient and at the same time useful lighting of the drawers. The LED strip, which is placed under the edge of the bed, illuminates the side walls of the bed, so you can see the intems in the storage net.
Meanwhile the LED strip inside the drawer takes care of proper lighting of the cargo space under the bed. The lighting system is tied to the original switch on the doors, witch turn on the interior lighting in the car. So, every time we open the door, the side lighting and the lighting in the drawer also comes on. If desired, the lighting can be switched off with a switch on the center console, located between the front seats.
Lighting of the cargo space under the bed.
Here you can see just how good the lights are working!
The space under the bed is very spacious and perfectly meets my needs.
In the space on left side I usually put away a bag with a computer, a bag with photo equipment, a bag with a drone, a bag with medicines siply and more...
In the right space, however, I usually store, kitchen utensils like barbecue, charcoal and stuff like that.
Here I also store things which I buy at the grocery store, and which don’t need to be in the fridge.
The lid through which I get to the cargo space below.
The lid is not hinged, so I can just lift it or remove it for easier access the things below.
Custom made mattress.
The entire bed now measures 180 cm in length and 142 cm in width.
From the material used to upholster beds and seat parts in motorhomes, 8 cm thick. They also sewed me washable covers that are very easy to maintain.
I usually sleep with my head turned to the back door, so the gap between the two front mattresses doesn’t bother me at all. I also sleep in such a position because, I can stretch my feet over the bed, so I don't miss the longer length of the bed.
However, the mattress are separated precisely because that I can move them away when I need access to the lower compartment.
I also had custom shades made for all the windows in the car, which not only to provide complete darkness in the car during sleep, but also make sure that the space in the car does not heat up too much in summer, and in winter there are no excessive temperature losses through the windows.
