101 - 115 of 115 Posts
GQ TD42Ti
Discussion Starter · #101 ·
Automotive tire Motor vehicle Tire Automotive exterior Bumper
Automotive tire Bumper Rim Tire Composite material
Automotive tire Bumper Automotive exterior Gas Wood
After painting, I cleaned all the contact surfaces and prepared them for assembly.
Tire Wheel Automotive tire Motor vehicle Hood
Motor vehicle Automotive tire Vehicle Automotive exterior Hood
Automotive tire Wheel Motor vehicle Bumper Automotive exterior
Motor vehicle Automotive tire Automotive exterior Hood Automotive wheel system
Meanwhile I sent the rest of the parts after sandblasting to electro galvanizing, cataphoresis and powder coating. (I also had prepared my front radius arms for the future - need to change polyurethane bushes for the OEM ones)
Hood Motor vehicle Automotive design Font Automotive exterior
Automotive design Automotive tire Gas Auto part Automotive wheel system
Musician Guitar accessory Cookware and bakeware Music Eyewear
GQ TD42Ti
Discussion Starter · #102 ·
All screws and the brackets that have not been replaced with new ones have also been renovated. I sent them for de-galvanizing and galvanizing again with yellow passivation.
Wood Engineering Auto part Metal Household hardware
Brown Wood Rectangle Twig Art
Since the water pump pulley was missing on the engine, I have made it according to the dimensions of the original one, which was kindly lent to me by my mate.
Automotive tire Camera lens Carbon Composite material Cameras & optics
Camera lens Camera accessory Circle Auto part Rim
Camera lens Camera accessory Lens Cameras & optics Teleconverter
While waiting for new parts to arrive, I clean all other parts that comes back inside the engine.
Automotive tire Gas Metal Machine Auto part
Pollinator Table Butterfly Gas Insect
Automotive tire Silver Gear Font Nickel
Nickel Gas Cylinder Auto part Aluminium
Automotive tire Gas Auto part Machine Metal
GQ TD42Ti
Discussion Starter · #103 ·
Almost at the same time, the refurbished head arrived and all new original engine parts that were ordered.
I ordered a lot of new parts, from a set of engine gasket, to new bolts and nuts for connecting rods, bolts for engine head, new screws for the exhaust manifold, engine mounts, bearings and piston rings, water pump, thermostat, ind ...
Wood Bumper Automotive exterior Rectangle Gas
Wood Handwriting Trigger Font Post-it note
Packing materials Gas Shipping box Packaging and labeling Box
to be continued ...
GQ TD42Ti
Discussion Starter · #104 ·
Then I started with assembling the engine.
I bought an assembly lube and a plastic gauge, to make sure that everything fits together perfectly an that there is enough lubrication for the first start.
Automotive tire Motor vehicle Bumper Differential Gas
Automotive tire Motor vehicle Bumper Automotive exterior Audio equipment
Fixture Bumper Automotive tire Automotive exterior Door
Automotive tire Automotive exterior Wood Water Auto part
Wood Gesture Finger Font Nail
Automotive tire Finger Bumper Tread Tool
Font Publication Gas Circle Book
Motor vehicle Automotive wheel system Engineering Gas Machine
When assembling the Idler gear, I found myself in a considerable dilemma as I wasn’t sure where the lubrication hole needs to be pointed. I turned to you, the members of this forum, for help and got the answer that I was looking for so that I was able to continue working.
Automotive tire Light Product Vehicle brake Automotive design
GQ TD42Ti
Discussion Starter · #105 ·
Then I attached the engine head to the engine block.
Automotive tire Motor vehicle Automotive wheel system Engineering Gas
I used a new set of the engine head bolts
Chemical compound Natural material Transparency Plastic wrap Plastic
I numbered the screws for easier tightening order.
Automotive tire Motor vehicle White Tire Light
When installed an injectors and glow plugs, I apply some aluminium grease just in case, so if it needed to remove them in the future, they will be going out a lot easier.
Tin Automotive tire Tire Fluid Paint
Glow plugs are from Bosch, because at the moment Partsouq didn't have the OEM ones.
Wheel Battery Tire Multipurpose battery Font
Ready to put the injectors in.
Gear Wood Gas Automotive wheel system Machine
Assembling the front timing case and valve rocker arm.
Automotive tire Motor vehicle Automotive design Engineering Automotive wheel system
Engineering Machine tool Automotive design Machine Auto part
Wood Art Metal Fashion accessory Auto part
Motor vehicle Automotive design Automotive tire Automotive exterior Automotive wheel system
GQ TD42Ti
Discussion Starter · #106 ·
It goes well together :cool:
Engineering Audio equipment Gas Auto part Machine
Motor vehicle Automotive tire Gas Engineering Automotive exterior
Motor vehicle Automotive engine gasket Automotive tire Industry Engineering
After galvanizing the radiator hose holder, I soaked it in liquid rubber. It looks like brand new!
Fluid Finger Drink Font Beer
Guitar accessory Finger Wood Nail Wheel
Hand Wood Finger Gas Nail
Putting the oil pan back on the engine.
Tire Wheel Automotive tire Motor vehicle Tread
Assembling fuel pump gear
Shoe Crankset Wheel Automotive tire Gear
I also bought original alternator, power steering and AC compressor belts.
One of the missing parts on the engine was also the alternator and AC compressor. I've bought brand new alternator from ebay (100A) and for AC compressor I took the one from my RD28T engine and just modify a bracket to suit.
Finger Thumb Font Nail Terrestrial plant
GQ TD42Ti
Discussion Starter · #107 · (Edited)
Almost done!
Tire Fuel tank Wheel Vehicle Automotive tire
Motor vehicle Automotive exterior Gas Auto part Machine
Motor vehicle Vehicle Automotive air manifold Engineering Auto part
Motor vehicle Automotive design Hood Vehicle Automotive exterior
I even had a valve cover sticker made to make the engine look like the day it was made in the factory. :cool:
Rectangle Font Wood Art Magenta
Motor vehicle Automotive tire Automotive design Tire Engineering
Installation of the rear main oil seal and flywheel (I also replace the bush pilot in center of crankshaft).
Automotive tire Gas Motor vehicle Auto part Machine
Automotive tire Motor vehicle Gas Automotive wheel system Rim
Wheel Automotive tire Tire Motor vehicle Vehicle brake
GQ TD42Ti
Discussion Starter · #108 ·
Considering that I don't expect excessive horses from the engine, I opted for a serial clutch set. The only thing that I change is clutch disk with ceramic pads on it.
Wheel Automotive tire Blue Gas Rim
Automotive tire Blue Automotive wheel system Road surface Gas
To be continued...
GQ TD42Ti
Discussion Starter · #109 ·
Let's move on.
I want to install turbo on this engine, just to be a little faster. So I've bought a brand new T3 / T4 hybrid turbine.
Packing materials Plastic bag Plastic wrap Plastic Electric blue
Yes, it's China made, and yes, it doesn't necessarily mean it's a totally crap.
I send the my new turbine rebalanced before installation, because that is the only major drawback of these turbines.
Sometimes it can be superficially balanced, and we all know where that usual leads ...
I chose this turbo because of a fast spool on a low rpm and the cost of it of course.
(Turbine wheel: Exducer 55.8mm, Inducer 64.8mm
Compressor wheel: Exducer 76.0mm, Inducer 52.7mm)
Automotive tire Motor vehicle Automotive lighting Rim Asphalt
The exhaust manifolds we can buy on Ebay, usual don’t fit our “European” cars, as they are mostly made for right-hand drive cars.
Our, left-hand drive has booster brake and brake master cylinder in the way so it doesn't fit, and that's why it is easiest to make an new exhaust manifold.
My friend already had a computer drawing of flange for his project, I only slightly adjusted it to my spec.
I had made a flange out of 15mm thick iron, cut out on a laser.
Automotive tire Wood Automotive exterior Gas Automotive wheel system
Welding elbows and T-pieces from which I will weld the exhaust manifold.
Automotive exhaust Wood Auto part Ammunition Automotive wheel system
Cut to exact length, welded together and ground all welds
Automotive tire Bicycle tire Bicycle part Line Fender
Tire Wheel Bicycle tire Automotive tire Tread
I also made a base on which the flange is screwed so that it does not bend too much during welding.
Automotive tire Motor vehicle Bumper Automotive exterior Gas
Welded turbine flange.
Automotive tire Motor vehicle Rim Automotive exterior Gas
Automotive tire Motor vehicle Wood Bumper Metalworking
Motor vehicle Automotive tire Automotive design Bumper Vehicle
GQ TD42Ti
Discussion Starter · #110 ·
I also welded brackets to the manifold, so that I could install the original thermal protection on it.
Bicycle part Automotive tire Engineering Gas Composite material
I simply cut a rectangle in the heat shield so I could attach the turbine.
Motor vehicle Hood Gas Automotive exterior Engineering
Wheel Automotive tire Motor vehicle Hood Automotive design
The difference between the compressor housing. Right one is from the RD28T engine.
Automotive tire Motor vehicle Bicycle part Rim Automotive design
Finished welding of the exhaust manifold
Wood Bicycle part Tire Rim Bicycle fork
Automotive tire Wood Bicycle part Rim Automotive exterior
The inlet to the exhaust manifold is perfectly aligned with the openings at the head outlet. A compromise had to be made between the round and square hole.
Land vehicle Automotive tire Bicycle part Rim Gas
Here it is seen that the round hole closes the exit on the head
Automotive tire Motor vehicle Rim Material property Gas
The square hole, however, is difficult as far as the transition is concerned then to the round end of the T-pieces that I used to just build the manifold.
Product Automotive tire Motor vehicle Wood Audio equipment
Manifold then went to the sandblasting
Automotive tire Bumper Automotive exterior Gas Auto part
GQ TD42Ti
Discussion Starter · #111 ·
And to machining the contact surface, so that is completely flat.
Automotive tire Bumper Bicycle part Automotive exterior Wood
I protected the exhaust manifold with 600 °C paint, which still sticks to the surface after 5000 kilometers driven :cool:
Automotive tire Motor vehicle Bumper Automotive exterior Automotive wheel system
Automotive tire Motor vehicle Crankset Bicycle chain Rim
Before I installed the oil pan, I drilled a hole in the engine block for the return the oil from the turbine.
I made a hole in the same place where the original TD42 turbo engine has a oil return.
The oil feed for lubricating the turbine is also taken in the same place as the original turbo TD42 engine had.
Automotive tire Grey Gas Font Automotive exterior
And the final look of the finished product.
Motor vehicle Automotive design Automotive tire Vehicle Automotive exterior
Automotive tire Motor vehicle Automotive design Engineering Auto part
to be continued...
GQ TD42Ti
Discussion Starter · #113 ·
if we continue the story...
It was time to brought the engine from my home workshop to my mates shed.
Motor vehicle Automotive tire Workwear Automotive wheel system Engineering
Both together.
The gearbox has also undergone a minor overhaul, namely the replacement of all oil seals, dust cuffs, new thrust bearing, sleeve clutch release and all springs.
I also replaced socket assy for transmission shift control and clutch operating cylinder.
And of course a good clean and lick of paint fot the end.
Toy Machine Art Carmine Fictional character
Toy Snow Art Auto part Paint
It was time to remove the old fella.
Tire Wheel Car Vehicle Automotive tire
Vehicle Car Hood Automotive lighting Motor vehicle
The difference in size between 2.8 and 4.2 gearbox.
Motor vehicle Vehicle Gas Machine Auto part
New gearbox in place.
Motor vehicle Automotive design Automotive exterior Hood Auto part
Then it was necessary to make a plate for the correct position of the right bracket. I reworked the original engine mount.
Automotive tire Motor vehicle Automotive wheel system Gas Rim
The motor had to be put in place for precise fabrication and removed again for welding the engine mount.
Tire Wheel Cargo pants Motor vehicle Automotive tire
Tire Vehicle Wheel Automotive tire Hood
GQ TD42Ti
Discussion Starter · #114 ·
The engine in its final place.
I must say, it was not as easy as I thought it will be to swap the engine. There were some problems with setting up the engine at correct position, I had to modificate the radiator bracket a bit and change the oil filters with the smaller ones, if I want to mount the new starter motor (which I didn't have, when I purchase the engine and transmission). As for electricity, I didn't find it so demanding as I got a lot of information on this forum.
Vehicle Hood Motor vehicle Automotive design Car
Then it was necessary to slightly modify the existing exhaust pipe and make a new downpipe with an exhaust temperature sensor.
In the end, I wrapped it with heat wrap to protect the surroundings from the high temperature. For the same reason, I also dressed the turbine with a turbo blanket.
Automotive tire Art Wood Plant Gas
Motor vehicle Vehicle Hood Car Automotive design
Automotive tire Automotive lighting Hood Carbon Automotive wheel system
I also replaced the radiator with a brand new, three-core copper-brass radiator. Unfortunately I don't have a picture of it.
It was also necessary to replace the radiator shroud.
(left 2.8 shroud, right 4.2 shroud)
Automotive lighting Cookware and bakeware Automotive tire Automotive exterior Eyewear
Yes, there is still a quite of work to do. The fuel pump needs a little more attention with that fuel screw and I want to put the top mount Intercooler on top of it.
EGT are running sweet (so far, I have managed to bring a fully loaded car (3300kg) uphill on the highway to 490°C).
There is no black soot behind me, which shows that I can add more fuel, but I would still prefer an intercooler first,
so as not to raise the exhaust gas temperature unnecessarily. And I'm currently running on 10 psi. Thinking to boost it up to 14 psi, when it's all done. It should be still on a safe side, wright? :)
Wheel Tire Land vehicle Vehicle Car
Wheel Tire Vehicle Car Automotive tire
Tire Plant Car Vehicle Wheel
Tire Car Wheel Vehicle Sky
Natural environment Wood Vegetation Land lot Natural landscape
For the end some exhaust sound and soot - or better - no soot (the rattling noise coming from my brake pads) :ROFLMAO:
GQ TD42Ti
Discussion Starter · #115 · (Edited)
Little update on my Patrol.
I added switch to a rear tailgate at the back, witch turn on my LED interior lights in my "kitchen and drawers" setup.
I also added a dimmer switch, so that I can either turn off the lights completely, or adjust the brightness intensity of the LED lights as needed.
I used a switch from a wrecked car which I found at a local junk yard and I think that this upgrade will make my life on the road a bit easier.
Brown Wood Amber Automotive exterior Drawer
Brown Automotive lighting Amber Motor vehicle Wood
Brown Wood Automotive lighting Amber Hood
Brown Wood Yellow Automotive exterior Vehicle door
Wood Automotive exterior Motor vehicle Automotive lighting Gas
