1 - 7 of 7 Posts
Weekend Warrior
Nissan patrol
So this could be a long shot but I was wondering what parts are interchangeable between Nissan Patrols and Nissan Titans?
What do they share that we can instantly rob from Titans?
Obviously Titans are a US model but with the Aussie dollar still strong is there stuff we can buy from the states?
Im under the impression the Titans are using Dana diffs??? :shock:
Weekend Warrior
Nissan patrol
Discussion Starter · #2 ·
I fear this thread may be a little illconcieved due to the fact that the new shape patrol probably has more in common with the titan and possibly the most in common with the old patrol, which is more than likely none at all....
I guess my biggest question is what nissan engines currently in production have a suitable overall driveline length to fit in a patrol that also have interchangeable adaptor housings at the rear of the transmission?
If you interchange a bunch of cash with some bloke in Brisvegas, I believe he can get you a RHD Titan. There's a post about it somewhere in here.
I know a lot of the in-cab switches are the same shape as the GU4.
Titan interchangable parts
We are doing a Titan into D40 navara conversion at the moment. You would be very surprised how easy it is.
The parts which swap straight over are.
Engine and gearbox full bolt in.
Front suspension arms
Front diff
Steering rack
Rear diff only need the spring mounts moved.
Brake master cylinder
We are fitting the 5.6L with a supercharger, and the 5 speed auto is getting a kit put in it.
The titans have the same wheel stud pattern as the patrols. Not the D40.
The titan and the new Y62 patrols are the same front chassis assemblies, so everything is interchangeable between them.
Cheers Heath
Hey Heath, the 5 speed auto is the re5 right? What kit is going in? Beefing it up?
I ask because I want to beef up my 5 speed for a turbo, but it seems the specialists for this auto are in the states, seeing as it's in the big Nissan trucks there.
1 - 7 of 7 Posts
