1 - 18 of 18 Posts
nissan/patrol
Hi guys just wanted to know if anyone has had the same issues with their patrol.last night I was going for a drive and all of a sudden car died it blew the 20 amp engine cont fuse replaced fuse and run fine untill accelerator was applied .with the button behind the accelerator taped up I managed to drive home but with intermittent accelerator .car shut down turn key off and started again idles fine but no accelerator WTF. Any ideas would be greatly appreciated as I'm not to flash with electrics:confused::confused::confused::confused:
Nissan patrol gu2
Hi have you checked for air leaks around intercooler hoses? Air leaks will cause what your experiencing no power under acceleration! Cheers
nissan/patrol
Yeh all the pipe work is fine think it might be electrical though ,wen I put my foot down there's nothing Pump accelerator still nothing and all of a sudden the revs kick in
nissan/patrol
Yeh kiwipatrol I replaced it with another 20 amp fuse and it blew 3times but I taped the accelerator button up and that stopped the fuses blowing till I got home.in the end I was in 3rd gear idling home because I live in the sticks no tow trucks for at least 600 Kim's
nissan/patrol
Discussion Starter #7
Under the bonnet it's a 20amp fuse engine cont. Next to 10 amp engine cont and 3 15 amp fuses for head lights and fog lights
nissan/patrol
Discussion Starter #10
so ive managed to rid myself of this problem and all i have done was disconect all electric fittings
and clean with contact cleaner.maybe it was my lucky day idk
HI Mate.
I had exact;ly this thing happen to my Patrol. Was very intermittent. Ended up being a short from my power chip wire (had worn through and would occasionally touch engine and short). Once i go tthat sorted....all good. Sometimes id replace the fuse and be able to drive away straight away and other times not...obviously the wire was still shorting on some occasions.
Hope this helps.
Boley
Hi, I have a similar problem on my patrol grx 2006 (gasoline). Some times it would stop accelerating and the check engine light appears and the car simply looses acceleration and power it will react like it was chocked. If you turn off and on the car the malfunction disappears and it would be ok for a couple of hours or days until it strikes again.
the scan says that is an error with the throttle body but already checked and switched with another patrol and the problem persist on my car.
does anyone have any idea of what it could be?
GUII ZD30DI Wgn
Please explain the gasoline reference? In case that was simply a mistake, are your sure you only have one fault code in the ECU, I would recheck because this sounds like limp mode, I would also check voltage to TPS, if you give us a full description I can give this post its own thread, this is quite an old one..
Hi, when I reffer to gasoline is that it does not run on diesel.
There is only one fault on the ECU it would show only when the check engine light and the failure are presenting. If the failure isnt presenting it would not show any failure on the ECU.
The voltage on the TPS is ok is under it regular voltage.
What do you mean with limp mode?
Really appreciate your help
Limp mode means that the ECU is reducing the injection as it considers there is a fault ( or inconsistency ) with the sensors it controls.
Two major sources :
1/ MAP pressure sensor if you exceed the max 'authorized' boost which is around 18psi, for more than a couple of seconds, This means you might have too much boost, with a VNT limiting screw badly adjusted ( or rod length if anybody touched it)
2/ the MAF sensor, if it exceeds some voltages below some thresholds ( 3.55V below 2000RPM, 3.88V below 2500RPM, 3.98V below 3000RPM, and 4.20V below 3500 RPM.
If modifications have been made to your Patrol, ( EGR blocked, exhaust...) this happens all the time.
Cure is
a) to screw a little bit the VNT limiting screw ( see docs in archive), or
b) to add one or several schottky diodes in serie with the MAF signal. Easiest is at the ECU imput, or
c) a remap
GUII ZD30DI Wgn
Now I'm more confused, what engine do you have if it does not run on diesel, the post is in the ZD30 section (3L diesel), are we talking about a 4.8 petrol here?
Yes sorry is a 4.8 petrol engine.
the failure has been intermittent. Sometimes it makes it some times it runs great. This weekend it appeared again but this time You can see some black smoke from the exhaust. Thought it was the MAF sensor,I switched from another petrol 4.8 patrol just to be sure before buying it but The failure appeared again and this time without the black smoke. really don’t know what can be happening here it seems weird.
the scan says that is a problem with the throttle position sensor (TPS) but already checked it’s working fine with regular voltage.
Is it possible that the tps just fails sometimes? since the car does not have the failure all the time it just comes and goes..
the failure keeps being the same: check engine light on, very very slow acceleration even with the pedal to the end and high fuel consumption.
thanks.
Yes, TPS creates problems sometimes. Either the micro-switches come dead, and/or the variable resistor itself.
If your problem is intermittent, you may have connection problems. buy a contact spray, unplug the plugs, and put some to clean the contacts to start with. Check also all wires, one might be damaged.
Sometimes, people add electronics which tap in the TPS signal, and if the soldering is not good enough... or if the connection is loose... that is also a source of problems.
1 - 18 of 18 Posts
