1 - 20 of 30 Posts
getting a growling noise when i ease of the throttle now , bloody anoying, nothing under power or off throttle:(
Discussion Starter #2
found the cause right front hub in engauged full time, found as i need to replace the bumpstops one broke so will do both
naturally asthmatic
You can fix the bump stops with a bit of glue and big lag bolt.
bugger 800 km trip its back with me again , disassembly coming up me thinks:rolleyes:
Previously known as twodiffs
1991 GQ Safari.
ok ta something to think about
got some gen nissan ones $85 nz
Or PM Nissbits on here....THEY ARE CHEAPER!!! ;)
I priced them from Nissan as well last week as I need the 4 centre mounts, got quoted the same as you.
I'm gonna get mine from Nissbits in the next month or so.
Discussion Starter #7
bumpstops installed. top plates not going back on, and been warned its the pinion bearing dieing
1991 GQ Safari.
Ignore my post above coxsy :rolleyes:, i thought you were on about body mounts and not bumpstops.
Discussion Starter #9
well body mounts will need looking at sooner or later, and found the noise excretive lash in the rear locker twice ran it at 100 kph on the road
Discussion Starter #10
put a tight lsd in today same noise there .so not the diff , gearbox is the last resort
Discussion Starter #13
and found out if the aircon belt lets go it damages the power steering belt too:confused:
4x4 Addiction
I had your same problem, mine started after my 4 inch lift, I was getting grinding sort of noise when I backed off the accelerator, it only last few seconds but sounds bad and faster your going the worse the sound is.
I had both unis replaced
Rotated tail shaft
Pulled the tail shaft apart and filled spline full grease, this made the noise almost disappear but only lasted for 1 hour of driving then it was back.
I then did a high pinion rear and zero driveline noises.
If you searched through the GQ section for drive line noises you would have found few threads on this topic and there is a high pinion thread there also with all the info you need.
Discussion Starter #16 (Edited)
all oil changed the truck full lubed , and the noise is still there, but clutch is on its last legs so turbo clutch fit gearbox noise , and reverce light switch :D when it dies:iconbana:
4x4 Addiction
Discussion Starter #19
put in the shop , clutch replaced by heavyduty sucker, gearbox has new bearings and thrush washers, should have it back by weekend
4x4 Addiction
Nice and quiet now? :)
1 - 20 of 30 Posts
