2010 GU DX
The central locking will only unlock the whole car when the reds are on and the drivers door is shut?
Seems odd to me, I would expect that un-locking the car from the outside with the key should unlock all the doors????
Second noob question, when you press the subtank switch should a light come on to indicate you are running off the subtank?
From reading about the subtank it pumps fuel across on startup, I just filled up both tanks so was thinking it may not allow subtank until the main tank is below full???
Still new to the car, and have searched/read/reading still around on the forum.
